Replacing lines from the fuel tank.
Old Jul 23, 2021 | 01:25 PM
OBS 4x4's Avatar
OBS 4x4 is on a distinguished road
Default Replacing lines from the fuel tank.
I'm in the process of replacing my gas tank because it was leaking, and decided to replace everything in that area because of rust. I was wondering about the 3 lines that come out of the fuel pump, does it matter which goes where? I'm assuming fuel is coming out of all of them but goes to different places.
Old Jul 23, 2021 | 05:55 PM
venom4ever4em's Avatar
venom4ever4em is on a distinguished road
They are different sizes and you cant mix them up.
Old Jul 23, 2021 | 06:37 PM
How are those shock absorbers holding up?
Old Jul 24, 2021 | 03:59 AM
OBS 4x4's Avatar
are you referring to the length or diameter? Ordered replacement line off rock auto and I got a bunch of it on a spool. The only one that's different is the bigger one that goes into the filler neck.
Old Jul 24, 2021 | 04:06 AM
OBS 4x4's Avatar
that's another thing I should probably replace, the whole thing rides kinda bouncy.
Old Jul 24, 2021 | 10:58 AM
Those lines are all different. One is pressurized fuel, one is a return line, and one is for vapor. If you're going to pull out the pump (and, from the looks of it, you should), it should be fairly obvious on the inside which is which.
Looking at that rust, I guess there is actually one good thing about living in California.
Old Jul 24, 2021 | 03:25 PM
OBS 4x4's Avatar
I actually bought a whole new pump assembly, figured while I'm replacing the tank I might as well do that too. I figured each line had a different purpose, is there somewhere where I could figure out which line from the fuel pump goes into which line in the car? I labeled the pic to help, does line 1 on the pump go to line 1 on the car? That's what I'm trying to figure out. Admittedly I should have looked before I cut them but too late now.
Old Jul 24, 2021 | 03:37 PM
It looks like you have 3 different hose diameters there. I would probably match them up based on that. I can't tell you off the top of my head which ones go to which. Mine only fit one way.
Old Jul 24, 2021 | 04:57 PM
OBS 4x4's Avatar
Just took the leftover hose off. It is 3 different sizes, the hose used is the same size for all 3 but the lines themselves are different sizes.
Old Jul 24, 2021 | 09:01 PM
I'm wondering if it'll be as easy as matching the sizes when you hook up the hoses...
Is there any way to tell which is which on the truck, if you don't already know, and the sending unit?
