Replacing rear freeze plugs
I did quite a bit of research before I did the job, and I believe that the '95 block does have freeze plugs at the back of the block. Before I pulled the transmission, I knew that the side plugs were leaking, but they didn't seem to be leaking enough to be the cause of all the coolant that was coming from my transmission. It was also nearly impossible to tell that the coolant was running along the top of the oil pan gasket.
Man... I must have been asleep when posting in this thread... I could have sworn we were talking about a '97... So yes, you would have had rear freeze plugs. I think I need to stop responding to so many posts at one time...
