Rod adjustment
Old Jun 20, 2008 | 05:50 PM
83Blazer's Avatar
83Blazer is an unknown quantity at this point
Default Rod adjustment
OK, I'm not to familiar with Chevy engines, I've got the stock 2.8 that came with my S10 Blazer and the engine is starting to knock, And I know that on alot of engines you can adjust the rocker arms/rods, is this possible for the 2.8? I'm wanting to try this to see if the knocking goes away, butI don't want to tear the heads off to check in case they are not adjustable.
Old Jun 20, 2008 | 06:29 PM
Default RE: Rod adjustment
A valve train noise is very rarely described as a knock. More like a tick. If you have a knock, that typically points to the bottom end, think rod bearings...
Old Jun 20, 2008 | 06:58 PM
83Blazer's Avatar
Alright I'll check again, thanks for the info.
Klturi421
Aug 2, 2011 07:21 PM
kaejr
May 22, 2007 01:01 PM
drperry
May 3, 2007 07:50 PM
Chevyguy032
Apr 6, 2007 05:15 AM
rlt7272
Suspension Tech
Mar 9, 2007 02:20 AM
