rough idle in gear at stop
Old Aug 25, 2014 | 12:08 AM
schapm5926's Avatar
schapm5926 is on a distinguished road
Default rough idle in gear at stop
2000 Chevy blazer LS 2 door 4x4 Vin w. I have replaced MAF ,vacuum lines, cap and rotor, plugs and wires, pcv, ignition coil, fuel filter, cleaned egr and throttle body, checked for leaks around tb housing, vacuum is good, fuel pressure good, and the CEL is not on. I've also replaced air filter. Blazer runs great on hwy but when I stop it idles rough up and down and occasionally dies which is not often. When I unplug MAF it holds steady idle. Any suggestions greatly appreciated.
Old Aug 30, 2014 | 11:28 AM
abig84's Avatar
you can try cleaning the maf. just buy some maf cleaner at autozone and hose out the inside. its amazing what that can do sometimes
dannyb91979
Jul 16, 2013 06:08 PM
clicheche
Mar 24, 2013 09:17 AM
1blazer99
Sep 27, 2009 10:55 AM
nathansr06
Nov 30, 2008 04:43 PM
ktfr4
Apr 8, 2007 11:14 PM
