rpm not increase when switch ac on
Hi every body,
I have problem with my 2wd 2000 gmc jimmy when I switch ac on,the rpm not increase still same like if ac off nothing change and some time rpm needle go crazy up and down some time it stay on zero
thank you
thank you
Could you provide more details to your description? It is not quite clear what the symptoms are. E.g. Is it engine speed? Is the tachometer needle moving erratically even though the engine speed is constant or only smoothly changing?
ReptileBlazer
Aug 23, 2015 12:55 PM
MindlessCorpse
Sep 28, 2007 07:32 PM
