RPM question
Yup it aint 5300 I knew it was in the 5000s just looked it up and its 5600, not that you should be getting the engine to this rpm anyway. I would say if your auto shifts at 5300 you have some issue. Mine shifts between 2500-3500.
Yep, in normal usage it does shift in that range. As I said, the 5300 shift was at WOT. I was running short-passes and only allowing the trans to up-shift one gear. It's certainly not where you would want it shifting on a continuous basis.
WHat you got some Coors in the back?! Eastbound and down!
