RPM question
Old Apr 24, 2009 | 04:12 PM
dragon55's Avatar
dragon55 is an unknown quantity at this point
Default RPM question
I just installed a Tach in my 96 blazer 4x4 and I want to set my redline, at what RPM does the redline start at?
Thanks
Old Apr 24, 2009 | 04:42 PM
Colby 04's Avatar
Colby 04 is on a distinguished road
5,000 RPM I believe...
Old Apr 24, 2009 | 05:19 PM
96chevblazer's Avatar
The red line is (look at pic)
Old Apr 24, 2009 | 07:00 PM
rriddle3's Avatar
My tach RL's at 5,500.
Old Apr 24, 2009 | 07:21 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Yeah it shows red at 5500 and partly red at 5000 up. If I recall it has a fuel cutoff at 5300 so you dont over rev though so the red line isnt really red.
Old Apr 24, 2009 | 07:26 PM
oh i didnt know there was a fuel cutoff at 5300
Old Apr 24, 2009 | 07:33 PM
rriddle3's Avatar
Dunno 'bout that. According to my tach, at WOT my transmission shifts at ~5300.
Old Apr 24, 2009 | 11:17 PM
portcqb's Avatar
Yup it aint 5300 I knew it was in the 5000s just looked it up and its 5600, not that you should be getting the engine to this rpm anyway. I would say if your auto shifts at 5300 you have some issue. Mine shifts between 2500-3500.
Old Apr 25, 2009 | 05:45 AM
rriddle3's Avatar
Yep, in normal usage it does shift in that range. As I said, the 5300 shift was at WOT. I was running short-passes and only allowing the trans to up-shift one gear. It's certainly not where you would want it shifting on a continuous basis.
Old Apr 25, 2009 | 08:19 PM
oisinirish's Avatar
WHat you got some Coors in the back?! Eastbound and down!
