RPM's jumping
Old Jan 17, 2008 | 02:37 PM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default RPM's jumping
my cousin has a 98 sonoma and just called telling me his rpms are jumping suddenly then coming back down to normal. i really dont know what could cause this?
can anyone help me out?
Old Jan 17, 2008 | 03:08 PM
WolfPack's Avatar
Default RE: RPM's jumping
how much of a 'jump'? are we talking 1000 rpms, or just 200 or so. If it's a small jump, it could be the torque converter locking/unlocking randomly
Old Jan 17, 2008 | 06:29 PM
thegr81's Avatar
Does it happen when he mashes on the gas??? If so it could also be a crankshaft position sensor issue!!
Old Jan 17, 2008 | 07:36 PM
WolfPack's Avatar
is there a way to test the crankshaft position sensor? Or is it more a set of symptoms that = bad sensor?
Old Jan 17, 2008 | 09:49 PM
thegr81's Avatar
The crankshaft position sensor will pop a code and there is a few things that can tell you its bad without a code, if you mash on the gas and the truck starts to buck and you hear a popping noise under the hood its the sensor also what I am going through till I replace mine is a rough idle as well!!
Old Jan 18, 2008 | 01:18 AM
ORIGINAL: WolfPack
around 500
Old Jan 18, 2008 | 06:38 PM
ok he says the rpms jump when hes just cruising, the PCM isnt throwing a code or anything either
he says other than the random jumps it runs fine
Old Jan 18, 2008 | 06:40 PM
thegr81's Avatar
Then I would say it might be the cable, it might be slipping at its attatchment point on the tranni, I have never heard of them coming loose but it might be a possiblility!!!
Old Jan 18, 2008 | 07:48 PM
hmmm his trans was just replaced by a not so renowned shop lol.
thanks man!
Old Jan 18, 2008 | 07:51 PM
thegr81's Avatar
Not a problem man hope thats the problem!!
