Running out of ideas...
Old Mar 26, 2012 | 09:47 PM
99blublazr's Avatar
99blublazr is on a distinguished road
Default Running out of ideas...
My parents have a 1999 Chevy blazer 4dr, 4.3L. Before I moved back to the area, they told me it was starting to act up. So upon arrival I went for a ride with them. Heres the break down:
When you start it in the morning, it starts up fine, but once you put it in drive, first gear chugs and sputters until you get into 2nd gear, and from there on its fine. However, once the car has been warmed up for a little while you can start it on and off through out the day and it drives through every gear like a champ.
I've checked plugs, fuel filter, and connected it to a Scanner (which showed me nothing). I am only hoping that someone has had this misfortune and has figured out the cause and a way to remedy this.
I've tried searching (here/google/bing) and found nothing really relating. Thanks in advace for a 1 post member.
Old Mar 26, 2012 | 10:38 PM
50lb_cat's Avatar
Did you clean the maf sensor?
Old Mar 27, 2012 | 12:10 AM
xgiovannix12's Avatar
warm her up good and disconnect the maf and see if this corrects the problem
if it does clean it with maf cleaner as stated above.. Most auto part stores have them
Old Mar 31, 2012 | 05:41 PM
jim109's Avatar
jim109 is on a distinguished road
if it dosent ?
Old Mar 31, 2012 | 05:58 PM
Clean it? i said it in my post
drummerboy1864
May 13, 2013 03:45 PM
Eff10
Sep 6, 2010 11:55 AM
jmatt07
Dec 18, 2009 09:48 AM
mrphy42
Oct 29, 2009 05:42 PM
agent305
13
Jun 4, 2008 10:24 AM
