S10 4.3 misfire after high rpm
Old May 26, 2025 | 08:00 PM
  #31
GeorgeLG's Avatar
Originally Posted by LesMyer
Most of the local auto parts stores in the USA have loaner tools (with deposit) like a compression tester.
I noticed that you are from a different country. Just curious which one. Austria?
If your rear O2 sensor is cycling like the front - then your catalytic converter is definitely bad. But that doesn't mean the cat is your performance problem - the P0430 is only an effect of your performance problem. Misfires are what kills cats. Also know that cats are not always restricted when damaged, which appears to be your case. Just forget about the catalytic converter until you have the engine running correctly. Back to basics!! Don't get lost in the OBD2 jungle!
You should rule out excessive back pressure as well as do the compression test that Les recommended. If there is no restriction then I agree, forget about the cat and work on getting the engine running right. BTW a volumetric efficiency test is another way to see if the engine is breathing correctly and also costs nothing.
George
Old May 28, 2025 | 07:53 AM
  #32
Arishynb's Avatar
Arishynb is on a distinguished road
Just ordered a compression test tool, gotta have one anyway!
Surprised you guessed right! Austria it is, at least for the last few years, not that common to loan tools here, found a few spots, but they have quite limited stock, plus it'd just be cheaper to buy one yourself- better in the long run too
Cat is most likely bad, but I agree, most likely not a root cause here. Gonna check the compression and the cat back pressure soon. Keep you posted, thanks guys
Old Jun 5, 2025 | 08:36 AM
  #33
Servus ausm Nachbarland.
Gruss aus der Schweiz.
Looking forward to the results of the compression test.
Old Jun 5, 2025 | 08:40 AM
  #34
Another thing that comes to my mind when misfires start at idle after a high rpm event...
...how good is the battery and the charge of the alternator? (Battery testing under load)
Old Aug 28, 2025 | 12:59 AM
  #35
RegSo's Avatar
RegSo is on a distinguished road
Did you end up doing the compression test? I'm invested.
Bryan Wiggins
Apr 8, 2020 01:18 PM
Naydog101
Nov 14, 2016 09:50 PM
neksys
Aug 15, 2014 11:54 AM
AfterBurn99
30
Sep 17, 2013 01:56 PM
jeffr_ca
Jul 19, 2010 10:25 AM
