s10 blazer, 101k miles, which trans fluid?
Old Sep 4, 2011 | 09:38 AM
rastoma's Avatar
rastoma is on a distinguished road
Default s10 blazer, 101k miles, which trans fluid?
My S10 Blazer 4x4 has the original tranny. It has 101k miles on it and runs really well for it's age. Every once in a blue moon it has a hard shift but I attribute that to the way I use the vehicle which is delivering mail part time so I do a LOT of quick start and stops. But other than that occasional hard shift it's smooth as silk.
I'm fixing to do a tranny filter replacement. Should I go with the high mileage fluid? Or just regular? I don't have the original owners manual. Does it take Mercron III? or IV? Is the multi ATF sold under store names such as Advance Auto OK?
I don't need to go cheap but if it's just as good there's no reason not to.
Oh, last question.... what goes in the transfer case?
Old Sep 4, 2011 | 11:43 AM
chris015's Avatar
Use the dexron 3. Ive used the multi atf,seems to work fine. Also add a bottle of lucas trans oil. Really helps! Dexron goes in the transfer case too!
AJC9725
May 18, 2018 09:36 PM
snuffy
13
Feb 20, 2015 07:50 PM
86blazeder
Feb 24, 2009 07:33 PM
luthers97blazer
Nov 10, 2008 01:27 PM
bblazer123
Jan 6, 2008 07:48 PM
