Same knock after rebuild
Old Dec 18, 2015 | 10:54 AM
  #21
Squatcher's Avatar
Squatcher is on a distinguished road
I was thinking maybe to much crush on rod bearing.
Old Dec 18, 2015 | 11:25 AM
  #22
LesMyer's Avatar
That distortion would cause wear at the rod/cap parting line due to side-pinch. See p 12 of the bearing diagnosis guide I previously linked to.
Old Dec 18, 2015 | 04:55 PM
  #23
Squatcher's Avatar
Ok also noticed this. Why the different rod caps the one on the left is the one that spun. Anyone ever seen a cap like this one on the left. All the other caps are the same but all the numbers are also in sequence. I should say all the other caps are the same as the one on the right.
Old Dec 18, 2015 | 04:57 PM
  #24
Squatcher's Avatar
This is the same two caps
Old Dec 19, 2015 | 11:11 AM
  #25
LesMyer's Avatar
There has to be a cut for the bearing tang in the right cap (just like there is on the left). You are definitely looking at two different sides of the rod caps in this photo, so I wouldn't expect them to look the same.
You do know the orientation for the rods on the right bank are supposed to be different than on the left bank (relative to the piston forward mark)? Is it possible you installed a piston/rod assembly in a cylinder that it didn't come out of (switched banks)? Did you mark both the rod and cap with the cylinder it came out of?
Connecting rod bearing tangs on rod/cap always go together on the same side of the rod and both towards the outside of the block. Notch in pistons goes forward. Two different connecting rod orientations, one for each bank of cylinders.
Old Dec 19, 2015 | 11:37 AM
  #26
Squatcher's Avatar
See the difference in this pic ...the cap with two notches isn't like any of the others .
Old Dec 19, 2015 | 11:43 AM
  #27
Squatcher's Avatar
And yes all pistons and caps was reinstalled the way it came out
Old Dec 19, 2015 | 12:29 PM
  #28
Squatcher's Avatar
Here is all six
Old Dec 19, 2015 | 07:57 PM
  #29
Squatcher's Avatar
Any ideas
Old Dec 20, 2015 | 11:27 PM
  #30
LesMyer's Avatar
Any ideas
That first one is just not right. Someone has been in there before you. That one can't be original.
