SAS Transmission Support beam???
Old Mar 25, 2013 | 12:01 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
Default SAS Transmission Support beam???
Ok so I plan on doing a SAS (leaf spring) and using ford axles so I can keep the stock transfer case and I noticed that stock with independent the front drive shaft runs along on top of the transmission support beam. So the new drive shaft would have to be at a really low angle to go underneath it, has anyone had this problem and what can be done to "fix" it???
Old Mar 25, 2013 | 12:23 PM
rexmburns's Avatar
Super Moderator
You have to modifiy the support to give the drive shaft clearance.
Old Mar 25, 2013 | 02:13 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Rex, do you know of a thread that talks about someone having to do that?? I either didn't pay attention or just didn't see it when reading the SAS threads on here. But this is something i have never taken into consideration so i am curious now as well! I have heard that you usually have to move or make a new front cross member tho.
Old Mar 25, 2013 | 03:27 PM
rexmburns's Avatar
Super Moderator
Yeah I misworded my original post lol! I should have said you MAY need to modify the cross member. Heres a good shot of one that is nicely done. Really its just a matter of notching it out enough to make clearance for the shaft. 4wdfactory used to sell one but I'm not sure they do anymore.
Attached Thumbnails SAS Transmission Support beam???-112279d1278924173-2004-4dr-blazer-img_1584.jpg
Old Mar 25, 2013 | 04:30 PM
Diaita's Avatar
On my Blazer, there was no way to use the factory crossmember. I even tried using an old 1.5" diameter Jeep CJ driveshaft and it wouldnt fit.
Here's how I did mine:
Old Mar 25, 2013 | 11:16 PM
Ohh ok yeah that makes sense. I mean a cross member wouldn't be too hard to make. I just never thought about that part.
Old Mar 26, 2013 | 07:06 AM
rexmburns's Avatar
Super Moderator
It's just one of those little details that is easily overlooked with everything else that's going on in an sas swap.
Old Mar 26, 2013 | 12:51 PM
Diaita's Avatar
A SYE is also a necessity when you get over about 5-6" of lift as well. I have not been able to get rid of my rear driveshaft vibration no matter how I change the angles, so once it warms up, in goes the SYE and CV.
Old Mar 26, 2013 | 01:11 PM
chestypuller's Avatar
Banned
chestypuller can only hope to improve
Just use a dodge or chev dana front axle abd swap to your 205 tcase on the passanger side
Old Mar 26, 2013 | 01:17 PM
rexmburns's Avatar
Super Moderator
You would still have to modify the cross member for clearance it would just be on the other side!! Not sure of your logic on this one?
