Scary problem
Old Dec 9, 2011 | 07:58 PM
OKBlazer01's Avatar
OKBlazer01 is on a distinguished road
Exclamation Scary problem
My wife was driving her Blazer today when her throttle suddenly stuck wide open, causing her to eventually get in an accident. She drives (well, drove) a 2001 Blazer with 4WD. Anybody ever hear of something like this happening? It was a very traumatic experience for her, especially as she had 3 children in the back seat at the time.
Old Dec 9, 2011 | 08:09 PM
Thogert's Avatar
I've heard of a cruise control malfuntioning and doing that, but it wasn't on a blazer. Is everyone ok?
Old Dec 9, 2011 | 08:13 PM
xgiovannix12's Avatar
ouch hope every 1 was ok
its possible the throttle cable froze
or like thogert said the cruise control
I never liked it and mine never worked so i disconnected mine
Old Dec 9, 2011 | 08:38 PM
trucktom's Avatar
trucktom is on a distinguished road
maybe throtle retun spring broke? i had a neon do this tps fell aprt inside and jammed
Old Dec 10, 2011 | 02:17 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
well i doubt the cable froze if it got stuck in WOT cuz that would mean she would have to be flooring it (which i suppose is possible). But im gonna agree with the cruise control idea. But im not sure how this would happen. maybe if she had the cruise control on and a vac line fell off causing the engine to think it needed more power (i think thats how cruise control works anyways) but im not sure if a vacuum line coming off wile in cruise control would cause this.
Old Dec 10, 2011 | 12:00 PM
Blazeredtodeath's Avatar
Blazeredtodeath is on a distinguished road
My truck stayed at WOT when the vacuum line that goes from the upper plenum to the brake booster popped out of the plenum. That was scary. I hope everyone was/is alright.
Old Dec 10, 2011 | 03:04 PM
abig84's Avatar
happened to my 93 when i first got it. i was offroad at the time, had it in 4low and punched it througha mud hole. if you try to fight 4low with your muddy brakes its a losing fight. it slowed it down but i still hit a tree going like 3-4mph lol. i checked over everything and just lubed and oiled everything. best bet is to throttle the heck out of it with the truck off and look athe cable under the hood. see if its hanging up or anything is broken.
also had it happen years ago in a stick shift 83. my own fault i was messing the vacuum lines and air cleaner and when i gave it gas a vacuum T got caught in the carb linkage and got stuck
Old Dec 10, 2011 | 03:20 PM
pettyfog's Avatar
Good she' and the kids are okay!!
As to vacuum line coming loose then Cruise causing it, I dont think so. Cruise uses vacuum to pull the cable to throttle so, no vac, no pull.
Cable 'Hang', that's something else.
Dont guess you'll be troubleshooting it, tho.. if it was my wife she'd never drive it again so you might's well hope it's totalled.
Old Dec 10, 2011 | 05:31 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
What about a simple "Pedal stuck on floor mat"?
Old Dec 11, 2011 | 12:07 AM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
Suggest to her that the engine has an off switch and the engine in a blazer is not more powerful than the brakes. No way she could not stop if she pressed the correct pedal.
