Scary problem
Old Dec 11, 2011 | 12:09 AM
xgiovannix12's Avatar
Originally Posted by David Hineline
Suggest to her that the engine has an off switch and the engine in a blazer is not more powerful than the brakes. No way she could not stop if she pressed the correct pedal.
when your in shock you dont think of these things
Old Dec 12, 2011 | 01:59 AM
Thogert's Avatar
If that happens to me, I am prepared to throw it into neutral.
Old Dec 12, 2011 | 03:38 AM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
I think one would have to be a rocket scientist to think of something like that for a solution, I expect most people would just let the vehicle go faster and faster and then steer into some object to slow the vechile down and stop it.
Old Dec 12, 2011 | 03:45 AM
Thogert's Avatar
Clearly you still have faith in humanity to believe such a thing, assuming that you were being sarchastic. I however do not have such faith. I've seen enough to know better than that.
Old Dec 13, 2011 | 01:30 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
that is true that you dont think about those things when you are in shock. who knows, maybe she was only 3 car lengths behind the car in front of her when it happened and had no time to think about anything.
But yes turning the engine off would be the best idea if that happened, or throwing it in neutral then turning the engine off before you red line and blow it apart, but that wouldnt even be a great idea because if its in neutral and you turn the key off you could turn it to far and lock the steering (i think), definitely cant if its still in drive tho.
Hindsight is always 20/20 tho..
Old Dec 13, 2011 | 07:21 PM
richphotos's Avatar
Some of the comments in here are pretty funny, First off, I am glad she is ok, Second, Its easier said than done to say you would throw it into neutral, or turn the car off, but when the situation comes up, you panic..
Old Dec 13, 2011 | 09:46 PM
Thogert's Avatar
True, you never know how you'll react untill it happens.
Hizapitt
Jun 23, 2010 06:03 PM
matthewcarter1014
Jun 2, 2008 09:30 PM
bdscholes71`
Oct 7, 2007 02:59 PM
TripleBlackBlazer
Sep 5, 2007 04:55 AM
sasquatchfound
Jul 19, 2007 10:14 AM
