Scratching my head
Old Apr 26, 2010 | 11:29 AM
dirt_truckin's Avatar
dirt_truckin is on a distinguished road
Default Scratching my head
I have a 96 blazer 4x4 wit a 4.3 lower end got wiped out so i replaced the cranck and berarings put it all back togother broke it in went to go for a test drive and nothing no fwd no reverse mind u i drove it on the trailer and off back into the garage and trans worked fine..... did not pull torque convertor or trans out..... what am i missing here plz help!!!
Old Apr 26, 2010 | 12:15 PM
I know this may sound like a stupid question... Did you remember to put in the torque converter bolts?
Old Apr 26, 2010 | 12:39 PM
Yea made sure of that lol
Old Apr 26, 2010 | 12:42 PM
The only thing in the trouble shooting chart for the 4L60E for no movement in any gear is torque converter bolts... You should at least have 1st gear. I suppose there could be a problem with the torque converter, but if nothing was removed, there shouldn't be anything that could have happened to it.
Another stupid question, the bolts were installed between the flex plate and the crank, correct? Also, worth checking is that the shift cable is attached to the transmission...
daanbc05
Feb 10, 2014 11:08 PM
4x4blazerguy
Jul 13, 2012 12:11 AM
ComputerNerdBD
Nov 20, 2011 12:15 AM
ComputerNerdBD
Jun 20, 2011 11:04 PM
n7rvn
Feb 20, 2010 09:28 PM
