seiged spark plug
Old Apr 21, 2009 | 06:52 PM
Falconator's Avatar
Falconator is on a distinguished road
Default seiged spark plug
Thanks for the reply about the tranny mount have'nt tried it yet but I will tomorrow. ok! I was doing a rotine tune up Changing spark plugs on my 93 S-10 Blazer and the plug on the right closest to the cab is stuck I am using heavy duty silcone and I warmed up the engine to operating temp it moved a little but will not come out.
Old Apr 21, 2009 | 07:29 PM
bandidolenny's Avatar
You are using heavy duty silicone on what? There is a such thing as heavy duty silicone? What makes it heavy duty?
As far as the siezed plug... Let the engine cool down and then get a six point 5/8" spark plug socket on it. Use a long rachet and put some oomph behind it in a counter clockwise direction. Worst case scenario has you pulling the head.
Old Apr 21, 2009 | 07:53 PM
rriddle3's Avatar
I would spray PB Blaster penetrating lube around the plug and let it sit awhile (maybe even overnight) and try again. Be sure to use anti-seize lube on the plug threads when you install them.
futuredoc
Oct 7, 2024 06:14 PM
4.3l trouble
Apr 7, 2019 06:54 PM
Yankee Team1020
23
Aug 3, 2011 08:05 AM
boulonman
Mar 5, 2007 05:10 AM
cuzfu
Nov 6, 2005 02:32 PM
