sevice engine soon light!!!!
ok i changed my exhaust a week or two ago and about two days after i was drivin from work and i work about 20 miles from home... and the ight aint on when u crank it but about half way home it comes one did i burn up something??
RE: sevice engine soon light!!!!
stock exhaust or custom made? Did you damage an o2sensor in one of the pipes and didnt realize it?
i put a cherry bomb on it... thats wat in thinkin but i have no clue where that would be at!!
I could be wrong here but theres a chance the back pressure in the system changed and the sensors are sensing that.. triggering the SES light..what code are you getting with the light? Maybe if you can get that info Kyle is pretty good with the codes for these trucks..
ight ill find out wat code im gettin
or it could be something totally diferent. I would find what code it is before attempting to pin point the problem.
well how do u find thecode
AutoZone or Advance Auto will read the codes for you for free.
You may have a fun time getting the codes read. If you have the OBD1 connector, then you may be able to do a simple paper clip trick and watch the check engine light. It will blink out the code. Refer to TroubleCodes.net for the code descriptions as well as a picture of what an OBD1 diagnostic port looks like. As the link above suggests though, some 95 blazers may not be able to be checked with out the proper scan tool. Most autoparts stores do not have the proper scan tool for checking these intermediary PCMs that were used in this year only.
If you have the OBD2 diagnostic port, then good luck getting the codes read. The DLC is located under the driver side dash. Here is what an OBD2 DLC looks like: http://i11.photobucket.com/albums/a1...h_OBD2_DLC.gif |
obd1.....so its gonna be hard.....
