shift slenoid help
Old Dec 15, 2011 | 12:07 AM
kjdmg's Avatar
kjdmg is on a distinguished road
4l60e trans
I can't pull up codes because vehicles been sitting with a dead battery for a while, and can't drive it to get codes set in.
Shift into od or any other gear and it sticks in first. No 3-4 gear. If I drop to 1, then shift up into 2 it will shift into 2 gear go to 3 and 4 it will stay in 2. Start from 4 it won't shift to 2, it just sticks in 1. I know that it is slenoids but don't know which ones. When it first happened I pulled codes, but can't remember what came up. I do remember one though, it was the torque converter slenoid or what ever tcc stands for. Please help motor was rebuilt and is sitting with under 10,000 on it. How many slenoids are there and what are they? If I need to change them all I will. TIA
It's 4 speed and reverse works fine also
Last edited by swartlkk; Dec 15, 2011 at 06:41 AM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Dec 15, 2011 | 05:58 AM
Does the speedo work? If not, then the vehicle speed sensor or it's wiring is messed up.
Digitized
Jan 12, 2014 12:07 PM
riggermm
Nov 4, 2009 06:06 PM
Blahman20
Nov 3, 2008 09:45 PM
firemansc32
Mar 16, 2008 01:33 AM
Bonovox
Sep 5, 2007 06:25 PM
