Shift solenoids limp mode? HELP
Old Jul 15, 2015 | 11:37 PM
Tommer2's Avatar
Tommer2 is on a distinguished road
Default Shift solenoids limp mode? HELP
2001 ZR2. Trans shifts good in all gears. Does not slip in any gear. I have a trans cooler on it. Here's the problem. On hot days or on real long drives the trans starts to act up. Running along at 60 or so and starting up a big hill it wants to kick down a gear from 4th to 3rd but won't. As it slows it feels like I'm in 2nd gear. Once over the hill it shifts up to high gear again and all is well until the next hill. I can stop and let it cool down for maybe a half hour and it runs good again. Is the trans going into limp mode. Could it be the shift solenoids? HELP!
Old Jul 16, 2015 | 01:16 PM
abig84's Avatar
if you dont have a external transmission cooler might be worth a try. ive seen the built in coolers in the radiator get clogged before causing transmissions to go all screwy.
crw2012
Jun 27, 2012 11:31 PM
kcub
Apr 16, 2012 09:53 AM
skidrew32
Apr 16, 2011 10:25 AM
mrblonde108
Feb 4, 2010 11:36 PM
BlackFireLS4.3
Jan 29, 2010 10:00 PM
