shifter in park....car in neutral
Old May 29, 2011 | 05:42 PM
sir loin's Avatar
sir loin is on a distinguished road
Default shifter in park....car in neutral
I have a 97 blazer Lt, 137,000mi., Automatic, (rebuilt trans. at 123,000mi). I got home, stopped, pushed button on shifter, put in park. Took foot off the brake and expected to sit still, but instead rolled backwards.So I depressed the brake and pushed the button to change gears, but the button wouldnt move. Now my shifter is stuck in park and feels like it moves farther forward then it should.... and I'm rolling like neutral. I have to use my E brake to sit still.
Any Ideas?
Thanks
Old May 29, 2011 | 06:45 PM
jpimp's Avatar
jpimp is on a distinguished road
weak dude, musta been a bad rebuild.
there is a park paul inside the trans wich sould engage park and stop the truck from rolling
also there should be a shift lock release located near the shifter itself to release it when no battery power or something like this.
I would start by checking the shifter cable down at the trans itself, it's on the drivers side of the trans.
pull the cable off and try to manually shift the trans right at the trans.
Old May 29, 2011 | 07:24 PM
sir loin's Avatar
I called the guy who did the rebuild but no answer. I went outside to see if it would start but nothing. I hear the fuel pump working though...
Old May 29, 2011 | 08:42 PM
warthogdriver's Avatar
i agree...check the cable position on trans itself...might be off some.
hope its just that simple for you
Old May 30, 2011 | 09:59 AM
sir loin's Avatar
It was raining last night so I checked it out this morning. The boot that covers the shifter cable was pulled off. It was connected with a bunch of electrical tape and the cable was bent in a wierd position. So I wasnt in neutral, I was stuck in reverse. Hit it with a bunch of PB blaster and reconnected with clean electrical tape until I find time for the repair.
Any good links or posts on how to change it out?
donald.dtgray.gray4@gmail.com
Dec 18, 2020 07:31 PM
TireGrit
35
Feb 6, 2012 08:04 PM
bam_9_9_9
21
Apr 10, 2011 09:19 PM
mick.p.
Feb 7, 2010 01:53 PM
prnswitch
Feb 16, 2006 03:57 AM
