Shifting Linkage with 350 turbo tranny on 76 K5
Old Sep 25, 2012 | 11:04 AM
Debaun68's Avatar
Debaun68 is on a distinguished road
Default Shifting Linkage with 350 turbo tranny on 76 K5
Over the weekend I put in a new tranny pan and attempted to change out the seal on the shifting linkage.. When loosing the nut to remove the shifting arm the truck had switched out of gear and went into nutraul. Not seeing were it was originaly positioned on the teeth I put it back where I thought it would be positioned in park. I put the pan back on and put the linkage back together and now I only have park and then it skips reverse and nutral and then goes directly into drive. Not good.. the other problem is the tranny is staying in the lower gear and not switching to the other 2 gears.. I know it's a alot but wanted to see if I could get some advice before I take it to the tranny shop... thanks..
Athlon2012
Mar 24, 2015 06:21 PM
ComputerNerdBD
Oct 16, 2011 08:01 PM
alstonfered
Jan 28, 2010 06:27 AM
quinn1991
Sep 27, 2009 09:31 PM
georgia_boy79
Jun 14, 2009 09:04 PM
