Shows reverse when I'm in 'park'.
Old May 12, 2013 | 05:09 PM
PhilParrott's Avatar
PhilParrott is on a distinguished road
Default Shows reverse when I'm in 'park'.
Hi there.
So I just had a transmission rebuild on my 2002 4wd blazer, and today I put a new Neutral Safety Switch on it. I'm having a problem though - when I have the car in 'park', it's showing as being in reverse on the driver display, and I can't get it to start.
Does anyone know what that could be?
Old May 12, 2013 | 08:49 PM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
The alignment of the neutral safety switch is off just a little. Just my opinion, did you use a repair manual when you change it? either way you may want to recheck it...
Old May 12, 2013 | 09:58 PM
rexmburns's Avatar
Super Moderator
X2 also check the shifter linkage adjustment it may be off just a small bit I had the same issue with mine and swapped in a new shift cable never had a problem since.
Old May 12, 2013 | 11:03 PM
Brilliant - thanks! That was it!
allenb1969
Apr 20, 2011 07:24 AM
travisrussell88
Shows & Clubs
Mar 27, 2011 08:17 PM
sprbld417
Jan 27, 2011 12:08 PM
88s10Blazer
Dec 22, 2009 10:33 PM
972disciple
Jun 15, 2009 03:02 AM
