Shudder on acceleration
Old Jul 30, 2007 | 12:32 PM
Trogger's Avatar
Trogger is an unknown quantity at this point
Default Shudder on acceleration
Nice site, first time posting. Unfortunately I can't seem to filter on a specific area.
Specs: '94 Blazer, 4.3, Vin "W"
Problem: Upon warm up the engine purr's, then when driving at any speed the engine shudders and tries to clear itself out as speed increases. It acts like an old Holley carb that loads up. Any suggestions out there?
Areas inspected/tested: Replaced fuel pressure regulator, fuel pressure within spec's, Cleaned out the IAC, changed O2 Sensor. CPI and nut kit looked fine-no leaks.
No known codes displayed.
This one is stumping me, I'd appreciate a path to look into.
Old Jul 30, 2007 | 10:31 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: Shudder on acceleration
Fouled or gummed plug(s)?
Old Jul 31, 2007 | 09:22 AM
Trogger's Avatar
Changed the plugs already with OEM Ac Delco, I should've added that to the items tested/replaced.
I have noticed that I have to clean the distributor cap-points every 4-6 months. I use a cordless dremel and a small wire brush attachment.
tdbone1
Dec 20, 2012 09:40 AM
noruckus
Apr 28, 2011 06:19 PM
seedsorter
Apr 3, 2009 03:59 PM
magtec
Jan 21, 2007 06:09 AM
tammikm
Aug 18, 2006 11:07 PM
