Shudder/Vibration in Reverse
Old May 11, 2011 | 10:31 PM
Bowers's Avatar
Bowers is on a distinguished road
Default Shudder/Vibration in Reverse
I have been having a issue with my 96 blazer. When i put it in reverse and give it gas it will shudder for the first few feet then stop. but i can be on a hill and roll backward and it wont do it. I have replaced and changed my tranny fluid and filter. I have added tranny medic to it. Nothing really made a difference. Also the blazer shifts great going down the road, no vibration at any other times. I was playing with my 4 wheel drive the other day and noticed when i put it in 4 low reverse i could not make it shudder at all.((Note 4 wheel drive is out, so front wheels was not pulling)) but it would shudder in 4 high. So that makes me wonder why it wont shudder in low but will in high. Could this be the tranny or my engine having a problem applying power to reverse since its a higher gear ratio.
Old May 12, 2011 | 06:45 AM
Motor/trans mounts making you feel things more? The higher gear would mean that the engine would have to work harder to move the truck. Reverse is a higher gear than 1st so it could be an ignition system (plugs, wires, cap, rotor, coil, ICM, etc) issue.
Old Jun 26, 2011 | 10:33 PM
Bowers's Avatar
Im still haveing this problem, I have noticed that when i put it into reverse and slightly apply gas it wont vibrate, but when it gets a little torque it does. Its like im running down a railroad track. Im going to take it somewhere and have it checked out while on stands or a lift to see what is causing it.
Old Jun 27, 2011 | 03:52 AM
kristoph30's Avatar
kristoph30 is on a distinguished road
It sounds like reverse is starting to fail. Low fluid pressure maybe? I know these trans had issues. Find a trans shop and talk to someone. usually they will know right away just from you telling them what its doing.
Old Jun 29, 2011 | 10:04 PM
Bowers's Avatar
Today I was backing out of a parking lot, and my truck started to make the vibration again and the sounds. My friend looked at my wheels as i was backin up and said my rear passenger wheel was vibrateing bad. I went to my uncles house, he looked at it as i backed up, and he noticed that same wheel was the source of my vibration. When i got home today, I jacked my truck up under the rear end so both back wheels would be off the ground. I put my truck in drive and accelerated, I heard my drivers side rear wheel starting whinning around 35 mph, but no vibration. I put my truck into reverse, and accelerated, but no vibration/sounds. I then applied the brakes, then power breaked in reverse. Then there was the vibration/shudder i have been haveing. I done it a few more time with the breaks applied, it would vibrate from about 0-3 mph in reverse but stop at anything over 10mph. I then let off the breaks and accelerated, but no vibration. I put my truck in park, got out and moved my wheels back and forth and pushed and pulled. I found a problem, my wheels have play in them when pushing and pulling, they will clank. I checked my lugnuts, they all tight, my hub has looked like it has gotten hot before. I have a few thoughts as of what it might be. 1 maybe my axles are going back, or 2 my wheel bearings are bad and causing some play, and maybe my vibrations. But i do beleive it is not my tranny or driveshaft/u-joint from what i had thought previously.
Old Jul 1, 2011 | 08:44 PM
Bowers's Avatar
today i had a good chance to look at things. I inspected my wheels and hubs, and rear end fluid. Everything seemed ok. I checked my tranny fuse it was good, but then i had the idea of takeing out my tranny fuse out and driveing it in reverse, It did not viberate then, but had no power in drive. I plugged my fuse back in and my it worked fine. I shut off my truck waited and restarted it and the problems returned, removed fuse and problem went away again. So why would my problem go away without a fuse in, and then return when i restart my tuck with the fuse.
Old Jul 3, 2011 | 01:15 AM
Bowers's Avatar
I beleive I am haveing an electrical problem. I got out and was playing with the tranny fuse again today. As i unplugged it and replugged it, i heard something click in or around my transfer case. I tried out my 4 wheel drive which was not working since i had the vehicle. And it worked. And my vibration was gone also. But as soon as i shut off my truck and waited and turned my truck back on my 4x4 was not working and my vibration returned. So there is something causing both problems.
jmac219
Oct 6, 2021 09:49 AM
noruckus
Apr 28, 2011 06:19 PM
2blzers
Feb 10, 2009 07:57 PM
magtec
Jan 21, 2007 06:09 AM
tammikm
Aug 18, 2006 11:07 PM
