shuts off while driving wont start
Old Jan 19, 2009 | 10:36 PM
azari215's Avatar
azari215 is an unknown quantity at this point
Default shuts off while driving wont start
90 S10 blazer shuts off while driving and has a hard time turning back on
i just recently replaced the battery distruptor cap and ignition coil
any idea on what could be wrong?
Old Feb 20, 2009 | 06:58 PM
Bruce S.'s Avatar
Bruce S. is an unknown quantity at this point
Default RE: shuts off while driving wont start
Hi azari,
Can't help you with this because I think we have the same problem.
My 4.3 Liter(non-vortec), 91' S-10 auto 4X4 runs for about 2 or 3 miles and then just flat out stops. It has been a slowly accumulating effect. Every once in a great while, over the past 2 years, my ride would stop. It would then immediately re-start. It is taking longer between re-starts. From instant to 20 minutes to 45 minutes to 1 and 1/2 hrs. and now to about 4 hours before it will re-start......and then run for another mile or 2. Overnight sit and it will start and run another mile or 2 to repeat the process. I live in a small CA town which helps, but boy is it frustrating.
I have switched out the fuel filter, battery,and the temp. guage sending unit, to no avail.
Have you had any luck figuring it your prob.?
[8D]
*Combining Consecutive Posts*
Well......I should have dived a bit deeper into the Forums. The following link shows promise. I will try it and post results:
https://blazerforum.com/m_196610/tm.htm
*EDIT by swartlkk* - Please use the EDIT feature to add additional information to your post if another member has not replied.
Thanks-will do in the future-B
Old Feb 20, 2009 | 07:46 PM
Bruce S.'s Avatar
Well, I replaced the coil....didn't work. I then replaced the ignition module(located in the distributor, under the cap, and held in by 2 screws)...and voila! that worked. My ride doesn't refuse to start and now doesn't just die on me out of the blue.
Hope this helps anyone.
B
Last edited by Bruce S.; Mar 5, 2009 at 08:13 PM. Reason: adding information so as not to waste precious bandwidth.
87K5BlazerKarl
Oct 22, 2010 07:02 PM
los2585
14
May 11, 2010 11:14 AM
BrnEydGirl
Mar 19, 2009 02:28 PM
nitro
Feb 6, 2008 11:37 PM
