Slipping trans.
I have a 96 blazer, auto trans, was driving the other day and the rpms all the sudden skyrocketed and my car slowed to a stop in the middle of the road. i shut the car off, put some Lucas stop slip in it, started it up, headed on my way, and it did the same thing about 250 yards down the road. i did this 4 or 5 times until i got it home and parked it. does this sound like a possible plugged filter?
Did you actaully check your ATF level, warm.. in park?
I believe in Lucas for slips, but if it happened all of of a sudden it wont help. If slip comes on gradually, Lucas takes a couple hundred miles to work.
You have another problem than clutch/band slip.
Take it to to good shop and have the pump pressures checked.
if that doesn't fix it i'm replacing the tranny with a 5-speed.
if replacing the filter doesnt work then, to me, the transmission is not worth fixing. the automatic transmissions in blazers are known for having problems, and once the start they dont stop. i would rather have the 5-speed anyways.
97jimmy4x4
Aug 22, 2010 02:48 PM
Spartan66
Oct 17, 2009 09:20 AM
oshkosh
Sep 4, 2009 10:27 AM
1995, blazer, blazerforum, clogged, filter, fix, forum, long, lucas, slip, slipping, stop, transmission, transmissions, work
