Bravada issues,Trans slipping off line?
Old Aug 16, 2009 | 07:36 PM
oshkosh's Avatar
oshkosh is an unknown quantity at this point
Default Bravada issues,Trans slipping off line?
Hello,
Well now besides my AWD being grabby it seems the trans started acting up more today...
Here are the symptoms....
About a week ago taking a two hour ride I noticed in traffic it started to get a little clunky in first gear,kind of shifting harsh in stop and go traffic.Once it cooled down(Engine temp was fine) it shifted fine.
Then yesterday I noticed a little surge at about 2,000rpm's in traffic and the check engine light came on(All fluids are good)...
Now this evening I headed out and it is acting like a dog off the line feels like it is slipping once rolling ok.On the way home I don't think it is down shifting under load now either.Backing into the driveway reverse was slipping before engaging(1st time it has done that)...I smelled after getting out of the thing almost a melting plastic smell for lack of a better description....
Am I witnessing my tranny about to grenade?
Make any sense to anyone?
2000 Bravada with 86,000 miles.
Old Aug 16, 2009 | 08:24 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
The smell is probably the fluid burning up,what is your tranny fluid level also do you see any transmission leaks
Old Aug 16, 2009 | 08:39 PM
oshkosh's Avatar
Fluid level has held steady for the past 6,000 miles(Time we have owned) and I had it on stands yesterday and there where no leaks(Pan was dry)...Fluid was a darker red but still red and didnt smell funny..
I was going to flush the transfer case yesterday then realized GM only fluid.lol Seems the list is getting longer.
The cat isn't clogged either checked that already.
Old Aug 16, 2009 | 09:15 PM
hkellogg's Avatar
hkellogg is an unknown quantity at this point
what was the check engine code ? was p1870 ?
Old Aug 16, 2009 | 09:35 PM
oshkosh's Avatar
Dont know yet,will put on a machine tomorrow...
Old Aug 17, 2009 | 05:28 PM
oshkosh's Avatar
Default New question same topic...
Does anyone know how many hours to swap out a transmission in a 2000 Bravada and or how many hours to rebuild a trans in the same.
I got a crazy or what I think is crazy quote today for a junk yard versus rebuilt.Both well over $2,000-
WTF I had my Ford rebuilt with torque converter and full Warr for $1,500 a couple years ago????
Old Aug 17, 2009 | 07:11 PM
hkellogg's Avatar
1800 is usually the average
Old Aug 17, 2009 | 08:33 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
you really should spend a hour looking through my old posts, it will save you time and money.
i am on the fourth trans in my truck, lol
i spent 75$ on a u-pull it trans - got about ~8000 miles outa it.
spent 1600$ to have the original(when i bought the truck) HD tranny rebuilt.
got burnt/scamed/whatever
spent another $700 to have all the steel hardparts removed from that trans and put in the junkyards trans and rebuilt.
EDIT: oh yah and swaping the trans isnt that big a deal IF YOU HAVE THE TOOLS!!! if u dont, well... its a nightmare, lol i could swap one in my sleep now though!
so in total i spent about 2400$ because i didnt get EXACTLY what the mechanic was doing IN WRITING!!!
lesson learned.
Im suspecting you have either ground or electrical issues though, maybe even a burn up BCM/TCM/whatever. take it to a free battery testing place and have em test your trucks electrical system under load. make sure your alt is keeping up with the system, these trucks go nutz when the ECU is underpowered. and also keep inmind if it is an electrical problem then YOU ARE CHEWING UP YOUR TRANS till you get it fixed, any damage done is permanent to a trannys guts (experts dont scald me im being vague I know).
read through my bull so u save yourself some, take it to a reputable (with the BBB) tranny mech.
Old Aug 18, 2009 | 03:02 PM
oshkosh's Avatar
Default Thanks for the heads up....
Thank You for the heads up....I have since gotten prices from $1,600 up rebuilt installed,the $3500 is the highest so far.lol
I myself don't have the time or a garage to dick with it and the days of laying on my back in the gravel are long over...I do have the tools and know how just not the other...Thats why I was having such a hard time with the $3,500 etsimate...
lesson learned.
Old Sep 4, 2009 | 10:27 AM
oshkosh's Avatar
Default Update,
Found a local shop to do the labor, turned out to be $611 with fluid etc... I found a guy who rebuilds transmissions as a side line out of his home shop(Used to do it full time,needed a job with benefits). Rebuilt kit; new clutches,seals bearings etc everything inspected for cracks etc $450 with core. So for $1,100 I have my truck back and running great...All in two days time. and four hours of my running around.
jsservin12
Sep 23, 2014 09:45 AM
mnusn
Jan 8, 2012 08:15 PM
97jimmy4x4
Aug 22, 2010 02:48 PM
Spartan66
Oct 17, 2009 09:20 AM
Brocktward
May 5, 2008 06:03 PM
