Sluggish Engine
Old Feb 2, 2026 | 12:09 PM
  #51
GeorgeLG's Avatar
Originally Posted by Shippiestshipper
Ok, I will look for the return, not sure where it comes out at on this but Ill hunt it down and try that, so with the return blocked, do you want me to drive it and see if the problems go away or take more test port pressure readings? it was a lot of drop but I am certain a fair amount was contributed to the rig I had to use to adapt everything leaking ever so slightly.
Everything for now is key on no start/wait ten minutes. Do not start the truck with the return blocked.
George
Old Feb 2, 2026 | 05:25 PM
  #52
GeorgeLG's Avatar
its a 2000 with 161K and as far as I am aware it's the original injectors. Lol should I scrap it all and stick a quadrajunk on it? lol at least those are much easier to remove when needed than what I've heard the spiders are lol
They do make that Echlin injector spider for your truck if it gets that far:
https://www.napaonline.com/en/p/CRB2...xoCQsQQAvD_BwE
George
Old Feb 3, 2026 | 09:45 AM
  #53
Shippiestshipper's Avatar
Shippiestshipper is on a distinguished road
Thank You!
Old Feb 7, 2026 | 04:15 PM
  #54
int3414's Avatar
int3414 is on a distinguished road
would it be possible/make sense, to remove the throttle body(not sure if that what its called), then with a bore scope,look in at the spider,,with key on looking for gas leaks??
Old Feb 7, 2026 | 04:39 PM
  #55
GeorgeLG's Avatar
we already know the leak is in the intake Plenum so he’s almost certainly going in there anyhow. The question is is that the Regulator or the spider
George
Arishynb
Aug 28, 2025 12:59 AM
JoshyB
Feb 16, 2018 06:17 AM
savage388
Dec 7, 2014 10:22 PM
GmcGentleman
Jul 10, 2014 08:42 AM
michael.tucholsky
Aug 22, 2010 10:57 PM
