smog pump location problems
i cant find my smog pump on my 06 zr2. back in 04 they had a recall on the hose going to the smog pump,and the hose decayed and peices fell into the smog pump and the previous owner didnt bring it in. so if you can help it would be much appreciated.
Under the radiator along the inside of the passenger side frame rail.
As far as the TSB goes (don't think it ever made it to a recall as it's not a safety concern), it was only on the design of the pipe. The old design pipe had a tendency to pick up water when it was wet outside which would result in a corroded pump over time.
Thanks a lot wuld you recomend the repair kits if i needed to get a new impellar or a new pumpo altogether
slk34
06-28-2007 10:07 AM
