Some Questions About A/C
Old Jul 18, 2012 | 11:11 PM
Majoraslayer's Avatar
Majoraslayer is on a distinguished road
Thanks for the tips, I didn't know all that. The gauge is one of the re-usable ones that comes with the cans.
Old Jul 21, 2012 | 07:54 PM
cucv30's Avatar
cucv30 is on a distinguished road
by the way how many cans did you put in?
Old Jul 21, 2012 | 08:21 PM
If I remember correctly (this was about a year ago), I put in one of the tall cans and about two or three of the smaller cans.
Old Jul 21, 2012 | 08:33 PM
cucv30's Avatar
Well they only hold 2 and a half of the 12 oz cans. But even if you over filled it, that would have nothing to do with the motor not running good when the ac is off. And i disagree with the notion of not adding oil unless you have something apart. Any time you have a leak you can lose oil. In fact that is usually how you can find a leaky connection cause it will be oily. Best way to find the leak is to fill it with just straight air and get out your squirt bottle with soapy water and check everything from fittings to front seal and condenser. Unless it is the evaporator leaking you should be able to find it pretty easily. Also check the pulley bearing as well to see if it's needing replaced.
Old Jul 22, 2012 | 06:12 PM
blazer_grl's Avatar
blazer_grl is on a distinguished road
A UV light will also help find leaks. The dye added with the refrigerant shows up really well.
88s10Blazer
Lifting Tech
34
Oct 17, 2010 02:50 PM
ImScrewed92
May 30, 2010 12:05 PM
davidluzader
Mar 1, 2010 10:25 AM
ZLover4Life
46
Dec 22, 2008 01:01 AM
scottyk
Mar 19, 2007 11:32 PM
