someone please help!!!
Old Apr 24, 2015 | 08:12 AM
matt.card's Avatar
matt.card is on a distinguished road
Default someone please help!!!
I have a 1994 blazer 4.3 engine code W. it has a rough idle, like its randomly misfiring when in park. If I'm sitting at a stop light the idle is even worse. When taking off from a stop it hesitates and shakes a bit. Driving down the road at 50 to 80 kph it works great but anything over 80 it will kick and buck and lose a lot of power when I try to accelerate or go up hill. I have replaced the fuel pump and sending unit, the fuel filter, fuel line, fuel spider, all new plugs and wires, rotor cap and button and the tps sensor. The fuel pressure is good, 60psi at start up, at an idle it holds steady at 52psi but jumps back to 60 when its revved up. There are no engine codes shown any time I check. I don't know what else to do to it, I'm running out of patients and I need help. Thanks in advance for any help.
Old Apr 24, 2015 | 08:22 AM
rexmburns's Avatar
Super Moderator
Could be a plugged cat
Old Apr 24, 2015 | 10:49 AM
matt.card's Avatar
Sorry, I forgot to mention that there is no cat.
Old Apr 24, 2015 | 02:00 PM
richphotos's Avatar
Take off your EGR valve and clean it.
Old Apr 24, 2015 | 03:22 PM
matt.card's Avatar
That was the first thing I did when it started acting weird
Old Apr 24, 2015 | 06:14 PM
richphotos's Avatar
What parts did you use for the plugs and wires/ cap/ rotor?
Still sounds like the EGR valve to me, maybe it was not cleaned enough, or there is some carbon in the intake valley for the EGR.
spikell
Oct 18, 2008 09:08 PM
drefda
Mar 27, 2007 11:07 PM
S10Blazer
Sep 25, 2006 03:18 AM
VORTEXV6
Oct 17, 2005 11:54 AM
TONY_ton
Aug 28, 2005 11:25 PM
