HF_monster |
05-10-2012 06:15 PM |
spark but still no start even with gas in intake
Okay so long story short, parts replaced and known good Fuel pump, fuel filter, FPR, Coil tested good using multimeter all plug wires had spark using spare plug and grounding method, cap and rotor cleaned, only code popping up is for the MAP sensor its a 1999 blazer.
Background on how it came to be this way driving down the highway vehicle just cutoff all electronics still working eg. lights radio and so forth. not overheating no valves hitting pistons anything like that engine was turning till the vehicle slowed below about 30.
I have read the sticky and dont have all the tools to do the tests but have used alternate methods to get the same results.
Im stumped and could use some fresh ideas, Im greatful for any help you can provide thanks
P.S. the gas down the intake was done with the fuel pump relay removed so the engine was not flooded
