spark but still no start even with gas in intake
Old May 10, 2012 | 06:15 PM
HF_monster's Avatar
HF_monster is on a distinguished road
Default spark but still no start even with gas in intake
Okay so long story short, parts replaced and known good Fuel pump, fuel filter, FPR, Coil tested good using multimeter all plug wires had spark using spare plug and grounding method, cap and rotor cleaned, only code popping up is for the MAP sensor its a 1999 blazer.
Background on how it came to be this way driving down the highway vehicle just cutoff all electronics still working eg. lights radio and so forth. not overheating no valves hitting pistons anything like that engine was turning till the vehicle slowed below about 30.
I have read the sticky and dont have all the tools to do the tests but have used alternate methods to get the same results.
Im stumped and could use some fresh ideas, Im greatful for any help you can provide thanks
P.S. the gas down the intake was done with the fuel pump relay removed so the engine was not flooded
Old May 10, 2012 | 06:22 PM
pettyfog's Avatar
What did the spark look like? Was it yellowish or blue ?
Old May 10, 2012 | 06:40 PM
HF_monster's Avatar
it was yellowish
Old May 10, 2012 | 11:24 PM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Cap and rotor! if you used aluminum ones throw em out and get delphi/delco.
Old May 11, 2012 | 09:50 AM
HF_monster's Avatar
Ill give it a try later today they both are relatively new but know that dosent mean much but their is no fouling on the terminals of either the cap or rotor
Old May 12, 2012 | 06:28 PM
98BlazerSL's Avatar
98BlazerSL is on a distinguished road
Had this same issue before and it was the cap and rotor. I had spark just not enough spark.
Old Jun 12, 2012 | 11:39 PM
mischden's Avatar
mischden is on a distinguished road
How did it turn out? I have the same issue of truck dying on highway so any help would be grateful.
Old Jun 14, 2012 | 08:25 PM
HF_monster's Avatar
turned out to be the rotor, but replaced both cap and rotor and still has a miss, right now its in the garage replacing both wheel wells and some patch panels but work load has been high so havent had much time for it
coolasice
Oct 10, 2013 09:33 PM
247monster
Jul 11, 2012 08:41 PM
jakem
Apr 15, 2011 03:56 PM
sedwards5390
Mar 25, 2011 08:17 PM
01blazer1981
Jun 26, 2008 10:57 AM
