spark plug change on the 4.3,how diffuclt we talkin?
Old Jan 14, 2010 | 09:30 AM
  #21
taba5's Avatar
taba5 is on a distinguished road
I did both my bravadas and it wasnt that bad, the wheels were removed so i could get my arms in there, just get a small clamp and fold up the floppy inner fender guard and rock out.
if the shaft of your extension is smaller it will help tons, and you can bypass the removal of the steering arm, by using said tappered extension
Old Jan 14, 2010 | 04:38 PM
  #22
ABN31B's Avatar
yeah, with the extension and a knuckle you can skip the shaft removal too (should have mentioned that part)
Old Jan 15, 2010 | 01:50 PM
  #23
97Bravada's Avatar
97Bravada is on a distinguished road
ok im seein AC delco is the consensis(sp) so i will def be getting those but idk bout the delco platnum..i like the cheap option lol,and i def have the proper tools to get it done so im gonna attempt it
Old Jan 15, 2010 | 05:03 PM
  #24
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
i'd go with the platinums. the tips last a little longer if you got to leave them in longer
Old Jan 16, 2010 | 10:49 AM
  #25
dsrp's Avatar
dsrp is on a distinguished road
gm engines prefer a/c delco plugs ,and i would put in regular delco
Old Jan 16, 2010 | 12:22 PM
  #26
97Bravada's Avatar
thats what i picked up last night at the parts store,the basic delco's were 2ish a piece and the platnums or what ever were like 4ish a piece,so i went w/ the cheaper option lol
Old Jan 16, 2010 | 01:00 PM
  #27
ABN31B's Avatar
plats last longer. so $12 to not change your plugs again in half the time isn't actually spending more money, it's a cheaper option in the long run.
that is why everyone from the admis down to the noobs told you that of everything and every option tried, everyone goes to/back to AC Delco Platinum.
It is not set in stone. I hope you get a long, healthy life out of those plugs. Good Luck.
Old Jan 16, 2010 | 02:28 PM
  #28
Banned
if you put in the best its gonna run longer and better. mostly this way with most parts. im big on you get what you pay for. more$ usually=better part. there is a few instances when this is different
Old Jan 16, 2010 | 04:00 PM
  #29
97Bravada's Avatar
i know the plats are prolly better but unfortunetly..i am unemployed right now and 13bux for regular vs 24ish for plats is better for me now,but i def appreciate the input and my next plug replacement will be plats
Old Jan 17, 2010 | 11:28 PM
  #30
toaks1's Avatar
toaks1 is on a distinguished road
what ever the factory put in in 2000 seems to do the trick! 124k miles later and they still spark, no missing or sputtering so i see no need to change 'em. also, i rarely take the rpm's over 2500 so im not too concerned with the mild decrease in performance that might exist.
