Spark Plugs !
What spark plugs has everyone used in their vortec motor? I have a 2002 4.3 xtreme blazer and want to do the plugs soon since it now has 64,000 miles... Normally in every GM i`ve owned its been nuttin but AC Delco plugs.. Any advice would be greatly appreciated...
RE: Spark Plugs !
I recommend staying with the AC/Delco Double Platinums.
RE: Spark Plugs !
Either stick with AC Delco or go with NGK Iridiums. I have ran both. The Delcos will run about $6 a piece and the NGK will run about $7 a piece. Iriduim is a harder metal than Platinum, and will end up lasting longer. You won't feel a difference in them, but the Iridiums burn slightly hotter. They both are self cleaning, so should last between 75k and 100k miles.
RE: Spark Plugs !
Please be aware that an iridium center electrode with nickel ground electrode, such as the cheaper iridium plugs have, will not outlast a double platinum plug. The nickel ground electrode will erode faster than a platinum tipped ground electrode in a double platinum plug.
So my recommendations would be AC Delco Double Platinum and if you can find them, a premium Iridium plug with a platinum ground electrode. |
RE: Spark Plugs !
check mate
RE: Spark Plugs !
the NGK Iridiums do have a platinum ground electrode.
RE: Spark Plugs !
I am runnin bosch double platinums, and they work pretty good.
RE: Spark Plugs !
I only used AC Delcos in mine and never had any issues. In fact, they lasted a lot longer than I expected.
RE: Spark Plugs !
ORIGINAL: 95_4door the NGK Iridiums do have a platinum ground electrode. ORIGINAL: thegr81 I am runnin bosch double platinums, and they work pretty good. |
RE: Spark Plugs !
my vote goes delco, expensive, but very much worth it. I payed $10 each.
| All times are GMT -5. The time now is 10:16 AM. |
