Spark Plugs !
What spark plugs has everyone used in their vortec motor? I have a 2002 4.3 xtreme blazer and want to do the plugs soon since it now has 64,000 miles... Normally in every GM i`ve owned its been nuttin but AC Delco plugs.. Any advice would be greatly appreciated...
Either stick with AC Delco or go with NGK Iridiums. I have ran both. The Delcos will run about $6 a piece and the NGK will run about $7 a piece. Iriduim is a harder metal than Platinum, and will end up lasting longer. You won't feel a difference in them, but the Iridiums burn slightly hotter. They both are self cleaning, so should last between 75k and 100k miles.
Please be aware that an iridium center electrode with nickel ground electrode, such as the cheaper iridium plugs have, will not outlast a double platinum plug. The nickel ground electrode will erode faster than a platinum tipped ground electrode in a double platinum plug.
So my recommendations would be AC Delco Double Platinum and if you can find them, a premium Iridium plug with a platinum ground electrode.
ORIGINAL: 95_4door
the NGK Iridiums do have a platinum ground electrode.
ORIGINAL: thegr81
I am runnin bosch double platinums, and they work pretty good.
