Spider injectors (again)
Old Nov 14, 2018 | 01:08 PM
Kibri's Avatar
Kibri is on a distinguished road
Default Spider injectors (again)
Hello.
Have tried to read on the pages here about spider injectors, but have not found anything about the problem I have. I have installed a new fuel pump and fuel filter, but had a problem before we did that, the car war idling rough and smoke a lot before it just died. Has now changed spider injector assembly, but now it will not start, it will ignite a couple of times and so just crank. Has a good fuel pressure, and has also tried starting fluid without any help from that.
Also tried to disconnect the battery for a couple of hours also turned on the ignition for 5 seconds, switched off for 15 seconds and tried to start without any luck.
Any ideas about this anyone?
Old Dec 6, 2018 | 06:57 AM
Kibri's Avatar
Now I have also switched the rotor, distributor cap, and ignintion coil, and then it started and went rough before it suddenly stopped again. After that it just cranked.
The engine light has started to light, but I do not get any error codes.
Hope that someone can give me a hint over what more that can be wrong
Old Dec 7, 2018 | 07:02 PM
Mike.308's Avatar
If it doesn't start with starter fluid it's not the spider.So, does it?
vegasfinest
Feb 27, 2016 07:22 AM
StarBlazing
Sep 21, 2014 03:55 PM
Paulpolar600
Jan 13, 2012 08:39 PM
Eff10
May 10, 2011 01:33 AM
kooz5
Mar 10, 2008 12:04 PM
