Stalling, not shifting till I let off gas
Old Aug 27, 2019 | 07:28 PM
Caleb Lav's Avatar
Caleb Lav is on a distinguished road
Default Stalling, not shifting till I let off gas
Changed my trans about 4 months ago, recently in first gear it would struggle to get out of first once it catches it runs fine, was driving home and now In every gear it doesn’t want to shift until I stomp gas and let go and barley going anywhere
Old Aug 30, 2019 | 10:31 PM
Caleb Lav's Avatar
I recently changed all of my 02 sensors, cleared my codes and now truck barley wants to shift and when accelerating goes very slow with high rpm’s I’m only getting one code two times which is P0135
Old Aug 31, 2019 | 09:57 AM
Transman304's Avatar
Might want to look at wiring harness that has O2 and transmission wiring for a pinch or rub through. Since you stated a recent trans swap. Also a failed MAF sensor will cause transmission and O2 issues. Good luck.
Brad
Old Sep 2, 2019 | 05:10 PM
Caleb Lav's Avatar
Brad
Looked at harness today took apart whole housing there was one wire split and some others were burnt, fixed wiring code went away, on my live code scanner it shows 0voltage still to that sensor and my truck is now shifting better but idling really bad, only code now is p0300
Old Sep 4, 2019 | 09:18 AM
Unplug the MAF sensor and start it. If it runs and idles good that’s where I would start. Maybe clean the MAF sensor also may help.
Brad
Old Sep 20, 2019 | 11:48 PM
Caleb Lav's Avatar
I’ve descoverd one thing
When I’m driving I’m loosing a lot of power & acceleration, shifting is slow, rough idle, causing a missfire & if I’m correct the bank 1 sensor 1-Oxygen sensor tells the computer how much gas to put for the air mixture, and when it doesn’t receive voltage it dumps gas, shows I have voltage when I start the truck, once I accelerate or press the gas I loose voltage until I turn the truck off for a couple min then back on
sending fuel system into OL-Fault
sabre420
Dec 7, 2018 05:25 PM
Brian_D
Engine & Internal
Dec 11, 2013 10:34 AM
gtmccormick
Sep 8, 2013 01:44 AM
BigTodd
Oct 15, 2012 05:39 PM
ultraz
Dec 26, 2009 02:33 PM
