Start up problems,please help.
Old Mar 21, 2011 | 02:03 AM
limited edition 1's Avatar
limited edition 1 is on a distinguished road
I have two blazers a 95 and a 01 trail blazer with the 4.3 motor. The 95 is addicted to starter fluid...it wont start without it, i've changed out the injectors,fuel filter and the fuel pump is working fine. i had the fuel pressure checked and was told it was good but i still have the same problem. I also have a 01 with the 4.3 motor and it has started to do the same thing,it's hard to start. I've changed the air filter,fuel filter and it hasn't helped...in fact it's getting worst. i really need help and don't want to buy parts i don't need.
I just read a tread from 3-16 and it's the same as mine....look's like i need a fuel pump. But I'm still not sure.
Last edited by swartlkk; Mar 21, 2011 at 06:14 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
Old Mar 21, 2011 | 06:46 AM
Please post the fuel pressure reading & leak down rate. If the pressure doesn't exceed 55psi and remain above 50psi for 10 minutes after the pump shuts off, you have a problem.
On the '01, you may want to try some fuel injection cleaner. Chevron Techron Fuel System Treatment Plus can often clean up sticky, gummed up poppet nozzles. Since you replace the spider in the 95, this likely isn't going to help there.
Old Mar 21, 2011 | 01:03 PM
ok thx, also im gonna try a new fuel pressure reg.
Old Mar 22, 2011 | 05:29 PM
new2zr2's Avatar
new2zr2 is on a distinguished road
Default Same problem
I've got the same issue sorry to hijack. My pressure jumps to 60psi when the ignition is on, the engine is off, and the pump is on. At idle there is around 55psi and quick snaps of the throttle give me between 55-60psi. The kicker is that within 10 seconds of turning the car off I have 0 pressure. I've tried using injector cleaners but not chevron. Any suggestions on where the leak is?
The main issues are hard starts after not driving for while and losses in power/hesitation as well if it hasn't been driven in a while. Should I start at the fuel pressure regulator or check valve on the fuel pump?
Old Mar 22, 2011 | 06:15 PM
new2zr2, since you have already done the right thing by posting your own thread, please lets keep the discussion there out of respect for the OP in this thread who has not yet resolved his problem.
welderman85
Jan 10, 2014 10:06 PM
opposedforces
Sep 1, 2011 02:59 PM
upblazer95
Apr 4, 2009 08:27 PM
BlazerPunisher
Mar 23, 2009 05:47 PM
rogggg1020
Nov 11, 2008 08:05 AM
