Starter problems... i think...
Old Aug 4, 2011 | 11:56 PM
Brian_D's Avatar
Default Starter problems... i think...
This morning when i started my truck there was a hard scraping noise after is started, kinda sounds like when you turn the key to much..
I took it to autozone to get the starter checked out.
the test came back as low cranking amps
You think thats the problem?
Old Aug 4, 2011 | 11:58 PM
chris015's Avatar
Low cranking amps...hmm..Have any friends that can lend you a battery to see if thats the issue?
Old Aug 5, 2011 | 12:01 AM
Brian_D's Avatar
He said my battery was fine tho, its brand new.
So its kinda confusing.
They tried to say the starter was going bad
Old Aug 5, 2011 | 12:43 AM
chris015's Avatar
Hmm. How or what did they test to see you had low amps?
Old Aug 5, 2011 | 08:57 AM
Low cranking amps is a measure of the batteries ability to discharge.
Did the sound start after the engine was running? If so, the starter could have stuck engaged into the flexplate gear.
Old Aug 5, 2011 | 10:16 AM
Brian_D's Avatar
They tested everything, battery came back as good.
starter said low cranking amps, it also said starter amp draw is low with ok starter voltage (check starter circuit for loose or worn wiring.
charging system test came back good too..
BTW this morning i went to go to work..
It wont start....
Swart - Yes it was after it started then it made the scraping noise. kinda like if you was to hold the key down.
But now it wont start at all just makes that ****ty sound and a couple other indescribable noises heh
i dont have the money for this crap right now too this sucks...
Old Aug 5, 2011 | 10:37 AM
Those descriptions kind of conflict IMHO...
If the noise was after the engine started, I would suspect a problem with the starter itself.
Old Aug 5, 2011 | 11:20 PM
Brian_D's Avatar
Yes - i didnt like the help i got at the advanced.
I was thinking the same thing.
Im gonna check into it more tomorrow and possibly replace the starter if that is actually the issue.
Old Aug 6, 2011 | 05:51 PM
Brian_D's Avatar
Looks like it was the starter.
Replaced it with a brand new one 162$!! bah!
O well tho it had to be done.
All is well now.
Just encase anyone wonders, you will have to loosen the transmission mounts to get it out.
Old Aug 6, 2011 | 05:56 PM
xgiovannix12's Avatar
wow you had to loosen the trans mounts ? i never heard of that being done unless its has to be done on 2nd gens only .
160 bucks for a starter sounds reasonable
