starting problems
starting problems
I have a 93 blazer s-10 series with the 4.3 vortec motor and we just replaced the fuel regulator like we were told to do,but it still won`t start ,they say it`s not firing.what could be the problem ?open to all suggestions
RE: starting problems
I also have a 93 S10 Blazer with the vortec 4.3L engine and had problems with failure to cold start. The only way I could start the Blazer was by using engine start spray. After having the Blazer in a shop, replacing the distributer cap and modulator, I took the Blazer to the Chevy dealer and discovered the fuel pump had an internal leak. It was hard to find the problem as after the vehicle would be started up the fuel pressure read as it should. A clogged catalyc coverter will also cause start up problems as well as decreased power while driving.
Have you checked the coil?
cgrett
11-15-2010 09:08 PM
upblazer95
04-04-2009 08:27 PM
Sprocket
03-20-2008 09:39 PM
Dean S
01-30-2006 02:51 AM
