Stock rear axle gear ratio 04 blazer 4wd 4dr
Old Oct 27, 2014 | 11:00 AM
BRoss99's Avatar
BRoss99 is on a distinguished road
Default Stock rear axle gear ratio 04 blazer 4wd 4dr
Anyone know the stock rear axle gears for a 2004 blazer 4.3l 4wd 4dr
Old Oct 27, 2014 | 11:37 AM
rexmburns's Avatar
Super Moderator
There are many different options look up your RPO codes to find what gears you have.
Old Oct 29, 2014 | 10:57 AM
El_Beautor's Avatar
Most likely you'll have a 3.42 (RPO GU6) or 3.73 (RPO GT4). Those were the most common axle ratios in the S-series trucks. If you don't have one of those RPO codes in your glove box list, then you can find RPO decoders all over the internet, or post the ones that start with 'G' and we can help.
Old Oct 29, 2014 | 01:09 PM
BRoss99's Avatar
Someone has ripped off that sticker in the glove box so i cant even access my paint code but i might call the dealership see what i got. Interested in your zr2 aluminium drive shaft swap was it direct fit?
Old Oct 29, 2014 | 06:11 PM
newguy's Avatar
Theres also vin decoders
Old Oct 31, 2014 | 03:32 PM
El_Beautor's Avatar
Like Newguy said, either the dealership or an online VIN decoder can give you an options printout.
I don't have the driveshaft from a ZR2, just the rear axle. The ZR2 Blazer driveshaft would be too short for my 4 door.
rickamp
Jul 2, 2014 01:47 PM
SCPratt
Feb 14, 2011 11:09 PM
scrmmealuvsong22
Oct 8, 2009 01:03 PM
NC93BLAZERLT
Oct 28, 2008 07:52 AM
cannibal440
Mar 6, 2008 08:28 PM
