Strange No starting Problem
Old Jan 30, 2012 | 09:09 PM
Theejonnyboy's Avatar
Theejonnyboy is on a distinguished road
Default Strange No starting Problem
I've been dealing with my 2000 blazer not starting for a a week now. It cranks good and strong but wont start. But also some days it will start.I have got it to start by cranking till you hear it start to catch. Then ill press the pedal alittle bit and it'll catch and run fine. My fuel pressure is 62psi and holds steady. I have spark but to be honest i have some cheap bosch spark plugs in there. I plan on changing them to AC Delco tommorow and see if this fixes my problem. Ive also replaced my crank shaft postion sensor. So what do you think???
Old Jan 30, 2012 | 09:37 PM
xgiovannix12's Avatar
did you run a leak down test ?
Old Jan 31, 2012 | 01:03 PM
The guy working on my car says its fine. The fuel pump was replaced less then a year ago
jmac219
Oct 28, 2012 04:38 PM
Campesino
Oct 9, 2007 03:57 PM
samurai_24
Jan 29, 2007 02:56 PM
Kellen
Sep 22, 2006 04:41 PM
xjeepguy
Apr 15, 2005 12:01 AM
