Strange Noise that has me baffled.
Old Feb 24, 2007 | 01:50 AM
Chevy Lover's Avatar
Default RE: Strange Noise that has me baffled.
It sounds to me like the right axle shaft is partially engaging in the diff. I ran into something like that once, pulled everything apart including the front diff 'cause I could see some wear at the end of the axle on the splines. I never could figure the cure so I ground 1/8" off the end of the axle and that was the end of the noise.
I sure wish I knew what the route cause of the problem was though....[sm=smiley29.gif]
I just found this info from GM
97-04 T1 vehicles with a grinding noise/vibration from the front axle in 2WD only. The noise is not present in 4WD. Front axle side/pinion gear finish, thrust washer worn, pilot bearing in stub shaft worn, and/or front suspension trim height incorrect
MisterBrusso
Aug 18, 2011 07:12 AM
jbsnowboarder16
Mar 25, 2010 12:06 PM
joethejman4us
Feb 16, 2010 09:25 AM
420BLAZER
Aug 28, 2009 10:38 AM
bkabina
Feb 25, 2007 08:41 AM
