Stroker
yea thats the kind of things i need to know, prices on those axles? places to buy?
You are going to want to search salvage yards and/or just keep your eyes open for an old 1ton GM truck stuffed back in the weeds or in a hedge row of some farmer's field. That is the cheapest method of getting them. You can typically buy old trucks for their salvage value, harvest off what you want from them, then cut up and recycle the rest.
That's what I am doing with my '90 Suburban parts truck. The motor, front doors, dash, A/C, and wiring are all going into my K5. I'll have a TBI 350, modern delay wipers, A/C, cruise, power windows/locks, etc.
And I wouldn't be so quick to revert to a carb. You can get pretty good performance out of a TBI motor and there are added benefits. One of them being off camber terrain where a carb has the potential to flood out leaving you vulnerable.
all depends on your carb. holleys you'll get more out of them but they are more temperamental and harder to tune. edelbrocks give you less power but are more consistent. all depends on what you want to do with it.
Myself, I can tune a Q-jet to perform as well as a Holley or Edelbrock. And Holley carbs are not temperamental for me either.
They all have one main flaw, a fuel bowl that can over flow at hard angles. Sure you can get a Holley Truck Avenger if you wanted to spend the money, but the TBI that he currently has will work quite well and is quite flexible if you are willing to learn how to use it. Don't fix what isn't broken.
sweet, so i'll go look in the bushes for one haha no really, its a good idea, never thought of looking at scrap for a good rear end
Don't forget the front too.
A Dana-60 from a 1-ton will bolt right in provided it is not a dually front axle. But a 1-ton 14BFF will have the spring perches would be set too wide. They would have to be cut off and welded on at the correct 42.5" spacing that your truck has (common to all other 1/2ton & 3/4ton GM trucks).
i know that site, im a member there i have an 88 camaro too, sounds good. THANKS
Does your Camaro have a TBI motor as well? If so, you'll kill two birds with one stone if you learn how to tune them!
yea its a 5 speed 5 liter TBI
what about computer tuning, ie. superchips? is there any plug and play systems to tune these engines or is the technology to old, it'll work for my maro too haha
