Tachometer Surging
I have a 2001 Blazer 4x4 lt. This problem just started where at normal driving with light throttle input, the tach starts bouncing. Acing like torque converter clutch is dis-engaging. Before I start trying to change the solenoids out should I check other things.
BTW over 300,000 miles
Already done
oil and filer
plugs, wires and cap and rotor
throttle positioning sensor
fuel pressure regulator
Already done
oil and filer
Already done
oil and filer
Already done
oil and filer
TCC in a 2001 Blazer is a fairly complex system controlled by the PCM. You can read about it some here.
https://www.sonnax.com/tech_resource...-modifications
just drive steady 60 mph and let off the gas and tap the brake pedal lightly. Do the RPMs rise about 200 rpm? If so the TCC was engaged and you just disengaged it. Now go back steady on the gas to watch it engage again and RPMs drop. Is this what you are calling the tach bouncing? If so, the only cure is to make the engine run better so the % load on the engine doesn't disengage the TCC so much (doesn't work as hard to maintain speed). Also know that the TCC first engages about 46mph and disengages at below 43mph or so.
No this is happening at various speeds as long as it’s a constant speed. Then when you let off the gas JUST A HAIR you will see the rpm drop which is normal then when you feather the throttle back on the rpm will raise a bit which is normal but then without moving the throttle when the rpm drop in order to maintain it will then start surging between like 1000 and 2000 until you move the throttle a lot to stop it. You can here the engine also, it’s like you are goosing the paddle. Also this only happens after the engine gets up to a normal temp.
BTW here is the full list of what I have done to the truck this year.
2001 Chevrolet Blazer LT 4x4
New stereo.
New speakers
Replaced speaker grills and defrost vent covers
Replaced oil filter and oil.
New fuel pump
New fuel pump access
New coolant reservoir cap
Flushed cooling system
New coolant
Vacuumed AC system
New refrigerant and oil
New fuel pressure regulator.
De-carbon manifold
New spark plugs
New spark plug wires
New distributor
New brake pads
New rear drivers side rotor
New rear drivers side caliper
New 3” suspension lift
New shocks
New off-road tires 31”
Cleaned and checked EGR
Cleaned and checked IAC
New Mass sensor
Replaced 1/2 vacuum hoses
Checked tightened valve covers
New 12000 pound hidden winch
New wireless winch controls
New idler arm
New lower ball joints
New sway bar links
Transmission flush
New transmission filter
New throttle position sensor
New fuel filter
New stereo.
New speakers
New fuel pump
New coolant
Vacuumed AC system
De-carbon manifold
New spark plugs
New distributor
New brake pads
New shocks
New Mass sensor
New idler arm
New sway bar links
Transmission flush
New fuel filter
rviolette84
Dec 21, 2012 12:25 AM
bwaynef
Jun 22, 2010 07:06 AM
Reyd_01
Mar 1, 2009 07:08 PM
