Tbi to Carb
ive got a tbi 305 in my 87 k5 and im looking at putting a 350 in it right now the 350 is carb what would be the cheap/easy thing to do? make the 350 tbi with a replacement manifold or change the fuel pump/regulater?
i believe in 87 they changed the intake mounting holes. so you might want to look at that before you try taking the intake off the 305 and try putting it on the 350 if its pre 87
either way is easy. if you go to carb you just get a HEI distributor and change the fuel pump or put a regulator on it.
maverik78
Performance & Brainstorming
Apr 11, 2010 10:05 PM
dcayers
Apr 12, 2009 01:51 PM
305, 350, 84, blazer, carb, carburated, carburetor, change, changing, chev, chevy, conversion, replace, replacing, tbi
