Is this the TCCM?
Old Jan 24, 2010 | 11:37 AM
JPate's Avatar
JPate is on a distinguished road
Default Is this the TCCM?
Traded a 94 Chevy Silverado Z71 for a 99 2 dr blazer 4 buttom 4x4 and the guy told me that the 4 x 4 works but need a new one of these. He had already had it out. So just need to know if this is the TCCM.
Old Jan 24, 2010 | 12:00 PM
old skool luvr's Avatar
to answer your question, yup. be extremely careful when replacing it (easy to screw the new one up).
but now i have a few questions. why did your buddy remove this, but not replace it? and how does he know the 4WD system works, but that this is an issue?
what was the truck doing (or not doing, for that matter) for him to remove it?
just trying to see what the problem is, and save you from spending cash unnecessarily.
Old Jan 24, 2010 | 01:43 PM
JPate's Avatar
I traded for this blazer. He told me the service 4 wheel light came on and had it read and it said it was the Tccm.
He said he did not replace it b cuz it would have cost him 300.00.
Old Jan 24, 2010 | 01:49 PM
JPate's Avatar
He did not state what it was doing. I might put it back in and see what it is doing
Old Jan 24, 2010 | 09:43 PM
@ your last 2 post:
.............ok, i got that you traded for it, i was just curious as to why he took it apart, and didn't put it back together? (even if he didn't want to buy the new part)
Old Jan 25, 2010 | 06:38 AM
JPate's Avatar
@ your last 2 post:
IDK. I guess I should have inquired alittle more on that.
Old Jan 25, 2010 | 07:20 AM
Lets back this up just a bit.
The picture you have above is the Encoder Motor, not the TCCM. The TCCM on a 99 is located behind the passenger side kick panel.
I agree with old skool though, we need some more details on what it is doing so that we can help you fix the problem with the least amount of $$ invested. I would put it back together and give it a try. See what happens.
Old Jan 25, 2010 | 08:53 AM
JPate's Avatar
I am hopeing to get it put back in on the next dry day or my good friend Moldeck will let me use his garage. i did not inquire to much about y he had pulled it out. I guess I was not thinking to much more then I was getting a better deal then he was on the trade.
Old Jan 25, 2010 | 09:45 AM
ejschultz's Avatar
ejschultz is on a distinguished road
You beat me to it. I've learned a lot about our 4x4 systems in the last couple of months getting mine almost completely functional again (still no 4 low, I think my transfer case and the used one I put in both have an issue with the 4 low gear). Anyways, what's your 4x4 doing? I had to replace my encoder motor and my vacuum switch to get mine functional again. If the TCCM from 95-99 remained unchanged (I do have OBDII), I've got an extra one that I'll be willing to sell you if that's for sure what you need.
Old Jan 25, 2010 | 09:50 AM
I do not believe that the NV233 TCCM changed in this time period (only where it was located), however, the OP has the NV236 transfer case (4-button).
