Temp guage / thermostat....ideas?
Old Jan 13, 2008 | 09:42 AM
dave5514's Avatar
dave5514 is an unknown quantity at this point
Default Temp guage / thermostat....ideas?
Hey all,
98 Blazer LS, wondering where your temp gauge normally points. Not a correct reading, I know, but ball park. Reason I am asking, she has 169,000 miles, engine surges between 1500 - 2000 andSES light is on.Some postings seem to point to engine not getting to proper temp. I just haven't had time to get the SES codes read, and you know those can be misleading too.
My guage points to the first qtr increment, never past that, could be about 185 degrees?
If you look at the gauge, far left is 100 degrees, 210 degrees is straight up and far right is red and 260 degrees I believe. the increments don't mathematically count right.
I believe that I need to replace the thermostat. Thoughts?
Where is yours normally. I only know of one person who has a Blazer, he sold it, but THOUGHT his temp gauge was always right at the 210 mark.
Old Jan 13, 2008 | 10:51 AM
Blazin_Jason's Avatar
Default RE: Temp guage / thermostat....ideas?
A stock stat should be 195, mine shows about 200-210 on the gauge. It does sound like you probably need to change the thermostat.
Old Jan 13, 2008 | 01:21 PM
All OEM gauges that read parameters that are normally constant or in a particularly tight range (oil pressure, coolant temp, voltage, etc) are made to be straight up when they are at or near the proper range. This is so it is easier to notice one gauge being off...
If you are only on the 1/4 mark on the temp gauge and the PCM is complaining about the coolant temp as well, chances are your t-stat has failed open.
Old Jan 13, 2008 | 06:39 PM
96Ls4Dr's Avatar
96Ls4Dr is an unknown quantity at this point
After I changed my thermostat(195), waterpump and headgaskets My temps went down alot.
Used to be 200-210 now its at a quarter(165-170) and blowing heat like never before.
I don't think it's normal but I'm not really worried about it either.
Old Jan 13, 2008 | 07:52 PM
Slow Rollin's Avatar
Slow Rollin is an unknown quantity at this point
I see you pulled the heads, how did you get the heads off the block? I am needing to put a new set of heads on my grandson 96 blazer. Cant seem to get to the bolts under the exhaust manifolds.
Old Jan 13, 2008 | 08:17 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
Take off the exhaust manifolds.
Old Jan 13, 2008 | 08:22 PM
LOL,,, we tried to, but the bolts are so rusted could not get them off. I did spray them with WD40. Can try again tomorrow night. Thanks
Old Jan 13, 2008 | 08:27 PM
HeyYou's Avatar
Well, it's not like they are in an unfriendly environment...... They can be a real bear to get off. PB Blaster is a bit meaner than WD40, and should be available at the parts store. I love the stuff. Sometimes, if they are 1/2 in. (just an example) you can tap a 12mm socket on them to break them loose. Occasionally, the mere act of beating on them with a hammer will convince them to break loose. But, in any event, the manifolds MUST come off to get the rest of the head bolts out.
As a last resort, you could torch the heads off the bolts, pull the manifold, and, once the head is out, extract the remaining portion.... It's an exercise, but, I have had to do it before..... Not a great deal of fun......
Old Jan 13, 2008 | 08:28 PM
That's a lot of rust!
You may need to bust the rust out from around the head of the bolt with a chisel and hammer (or air hammer with a pointed tip).
Old Jan 13, 2008 | 08:32 PM
Thanks for the IDs, I am also thinking about a impack wrech, just don't want to break the studs off, but I guess they could be replaced once I get them off.
